北東北 LabVIEWユーザー会
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
LabVIEW G-code Sender
Sorry for the confusing post.
Download “lvGS_demo.zip 154 KB” in the third message (10-09-2017 03:56 AM) of this post.
0 件の賞賛
メッセージ11/13
1,346件の閲覧回数
Hello
I want to use this project. To control X, Y and Z axis, but only for X axis, the G-Code program works, for other axes like Z, the motor rotates at uncontrollable speed. I used the DVD-DRIVER engine. Please guide me for this.
すべてをダウンロード
0 件の賞賛
メッセージ12/13
546件の閲覧回数
Hello sdmi1379,
Your device has a problem where you can control the X-axis but not the Z-axis.
The G-code Sender only sends a string of G-code, so if the X-axis works properly, the G-code Sender is probably normal.
I think you are using the GRBL software, but I think you should consider whether the version is appropriate. In the photo of the board you attached, it looks like you are using a slightly old CNC shield V3.0. The latest version of GRBL is ver1.1, but the board you are using is old, so I think it would be better to check the operation using ver0.8 that matches the board.
Also, the motor driver board used for the Z-axis may be broken, so swapping the X-axis board and the Z-axis board will help isolate the cause.
I hope this information is helpful.
0 件の賞賛
メッセージ13/13
537件の閲覧回数
