3D Vision
Azure Kinect Support
Now that the 4th version of the Kinect device is out in the wild, is there anyone that can help me import the .net libraries to a LabVIEW project?  I am running into the error "An error occurred trying to load the assembly." and have tried several fixes, with no avail.  Here are the articles I have tried.  I am running LabVIEW 2019 64-bit with the Azure Kinect 1.3.0 SDK.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=en-US
https://www.ni.com/docs/en-US/bundle/labview/page/loading-net-20-30-and-35-assemblies-in-labview.htm...
https://www.ni.com/docs/en-US/bundle/labview/page/loading-net-assemblies.html
Thanks in advance for any tips!
Side note:  You do not need the camera to install the SDK and .net libraries.
(9,454 Views)
As specified in the first link you provide, if the provided assemblies are 32-bit, you cannot load them in LabVIEW 64-bit. Do you know what is the bitness of the .NET assemblies?
Marc Dubois
(9,418 Views)
The assemblies are currently only in 64-bit.
I attempted to import them in both the 32-bit and 64-bit LabVIEW.
I would be very grateful if someone else could try importing these libraries as maybe I am missing something simple.
Thanks again!
(9,410 Views)
Hello M4goo,
I have the same problem as you 1 year after!!!
Did you have find a solution to integrate the Azure Kinect to a LabVIEW project?
Thank you for your return.
(8,870 Views)
Did you ever get the Kinect Azure sensor to work with Labview? Does Kinesia or MakerHub support the new Kinect Azure camera system?
(8,133 Views)
Azure Kinect Sensor & Body Tracking - NI Community
Azure Kinect Sensor For LabVIEW has been released, you can download and test!
(7,620 Views)
