AGH University of Science and Technology in Krakow
Can someone help me with simple aritmetich operations?
Make the quotient of two numbers and the resulting remainder -if any- using only addition and subtraction.
(4,067 Views)
What programming language?
(you probably need more than addition and subtraction, such as e.g. comparisons and loops, etc.)
(4,052 Views)
i am programming whit labview 2016 and probably in need more than add and subs but i dont now how can i use more tools in the program.
Could you advise me how can i program that?Ç
Thank you and have a good day
(4,029 Views)
Are both numbers positive or does it also need to work with negative inputs?
First try to come up with an algorithm, independent of any programming language. Do you have that?
(4,024 Views)
