 garyzero2910
			garyzero2910
			11-16-2015 12:38 AM
Hi !
I want to ask questions about the delay in ar drone images labview caused because when I shake something in the video, I feel there will be a slight delay of the phenomenon, I do not know whether other people have in the use of the type of problems?
11-16-2015 07:57 AM
There is a delay of the video stream. This is mainly caused by the wifi connection (which is not one of the fastest connections...). Also LabVIEW has to process the video, which also caused some delays.
This is less than 0.5 seconds but can be annoying if you are following an object. I recommend you to use some kind of position prediction if you need to. This might compensate the delay.
