Academic Hardware Products (myDAQ, myRIO)
3 wire analyzer error
I have been getting this error message:
 "the no of loops exceeded limit"
What does it mean????
I am trying to draw transistor characteristic curves. I can't even draw 2 curves.
(6,109 Views)
Hey Beefeater,
       So, I'm not sure what kind of hardware or setup you have, but I found some information that should at least point you in the right direction:
The "no of loops exceed limit" refers to the fact that the desired value is not reached within the given number of iterations.  I believe that in later versions of the software the error has changed to "The desired Base Current value could not be reached", which is a little more descriptive. It appears that this is an issue that has been fixed in the latest verison of the NI ELVIS software. Please note that if you install that software, you'll want to first have DAQmx 8.9.5 installed.
Thanks!
(6,100 Views)
