Academic Hardware Products (myDAQ, myRIO)
Analog Waveform through NI ELVIS to see it in a Oscilloscope
I had been working with NI ELVIS in LabVIEW 7.1 treating to build a analog waveform from a binary sequence, now that i have it i need to take it out from the computer through the NI ELVIS to see it in the oscilloscope. Here is the problem, how can i take out the waveform through the NI ELVIS.
I would be gratefull for your help, i realy need it.
(7,924 Views)
Hi Mox83,
That depends on the waveform you need to create, you can use the Function Generator VIs or the Variable Power Suply VIs, and you will have a signal on the pins marked in the protoboard in you ELVIS, depending of the VIs you use.
Tania Lozoya
(7,920 Views)
thanks Tania Smiley Happy
          I realy appreciate that you answer me. I am using tha ELVIS in bypass mode and that's why I don't want to use the Function Generatior VI's. I planning to use from the Data Acquisition the Analog Output VI's.
        Finally I did it.  Watching  a example that came's with the ELVIS I could do it. I Attach tha part of the VI that y use in this post.
   I hope that this help anyone with tha same problem.
(7,901 Views)
Cristian Boyain
(7,900 Views)
