Academic Hardware Products (myDAQ, myRIO)
Barometric Pressure Sensor
I am wondering if anyone has used a barometric pressure sensor with myRIO board. If yes can you suggest any good accuracy sensor?
What about this? http://www.embeddedadventures.com/barometric_pressure_sensor_module_mod-1009.html
Will it function properly with myRIO?
Thank you,
Christos
(5,502 Views)
Accepted by topic author ckyamaha
Hey Christos,
Looking at the sensor you linked, that should work just fine with the myRIO. It uses the I2C/SPI protocols to transmit its readings to a controller, and the myRIO has dedicated pins for I2C/SPI communication. Therefore, you should have no problems pulling pressure measurements from the sensor.
The myRIO also has a 3.3V output pin for powering external sensors, so you should be able to power the sensor directly from the myRIO as well.
I hope this helps!
Ryan
Ryan P.
CLA
(5,487 Views)
