Academic Hardware Products (myDAQ, myRIO)
Connecting myRIO with DALLAS 18B20 temperature sensor
Hi there,
I am new to the NI myRIO.
And I got a problem right at the beginning. I want to connect my DALLAS 18B20 temperature sensor with my myRIO.
It is a 1-wire interface sensor and it provides digital temperature measurements.
What I finnaly want:
I want to read out the temperature from the 18B20 and show it on the Frontpanel as a thermometer in real-time.
My Problems:
How do i have to connect this sensor?
How to get the data, it is "sending"?
My german is better than my english, so feel free to answer in german 😄
Thanks for your help!!
Message 1 of 14
(17,158 Views)
Hello Shoura,
maybe this would help you out
OneWire Utilities - Interface Innovations Toolkit and Applications for Maxim 1-Wire Devices
https://www.ni.com/en/support/downloads/tools-network/download.onewire-utilities.html
Message 2 of 14
(17,135 Views)
Hi jSturm,
Thanks for that. Looks pretty nice, but it does not work 😞
I don't know, what I am doing wrong.
Let's try it step by step.
Where do I have to connect the DS18B20?
I connected it on the right side of myRIO at 5V, DGND, DIO7 (Picture will follow!)
Is that correct?
I just did this yesterday and put an myRIO-Digital-Input in my LabVIEW programm. The return of this Input is always "TRUE" if the programm runs.
Message 3 of 14
(17,120 Views)
Hello Shoura,
you want to connect it like in datasheet figure 5?
Did you also use a pullup resistor 4.7 as you can see in the picture?
Regards, Julia
Message 4 of 14
(17,114 Views)
Hi Julia,
For me, it doesn't matter, how it is connected 😄
If it works, it's fine 🙂
At the moment the sensor is connected directly to myRIO.
At the end I just want to have kind of a thermometer. (I will post a picture today)
Message 5 of 14
(17,098 Views)
And what about the pullup resistor?
Here you can see how to connect it:
http://fluuux.de/wp-content/uploads/2012/09/Pinbelegung_ds1820.png
Message 6 of 14
(17,090 Views)
So i need this pullup resistor?
I did it just like you can see at the picture 🙂
And as I said, if I put a Digital Input (found at myRIO palette) in my LabVIEW programm, I get TRUE as an answer. If i take the sensor away, the answer is false.
Message 7 of 14
(17,080 Views)
Yes you need this pullup resistor
Andi
Message 8 of 14
(17,058 Views)
Ok.
The pullup resistor is set between the sensor and his former slots (like you could see in yesterday`s picture).
So this setup is ok?
Or anything else to change?
Message 9 of 14
(17,050 Views)
Hi Shoura,
please set it up like you can see at the following picture:
When you do this it should work fine.
Andi
Message 10 of 14
(17,044 Views)
