Academic Hardware Products (myDAQ, myRIO)
Controls/Decorations
Well, it's not a subpanel. It's just probably a combination of decorations.
You again attached a word doc. Just attach the actual picture. Why would you want to take an image and then paste it into word. It's just an unnecessary extra step.
It's probably better to focus on the LabVIEW fundamentals instead of making a pretty front panel. That's often the last step in a project and it's often overdone.
Message Edited by Dennis Knutson on 05-05-2009 04:05 PM
Message 11 of 13
(3,425 Views)
I'm trying to set Type.Def for a control type definition and having a difficult time doing it. When I right click the cluster border of "Analysis Results" cluster of my vi and select Advanced, there isn't any option to customize the control. Instead I see only synchronous display option.
Please see attached vi and see if you can set a TypeDef for the Analysis Results cluster.
Message 12 of 13
(3,384 Views)
You first need to unlock it. Draw a window around it to select it and then click the Reorder button on the tool bar. Select Unlock.
Message 13 of 13
(3,377 Views)
