Academic Hardware Products (myDAQ, myRIO)
DC motor experiment with myRIO
I am trying to use the mechatronics kit which came along with myRIO kit. I want to perform the control of DC motor experiment with myRIO. I have the code for the same on LabVIEW but I am not able to find the connections of the encoder motor to myRIO.
I found few examples which show connection using a breadboard, but for the DC motor I have, it is supposed to be used directly wired to the myRIO but I am not sure of the pin numbers on which this connection is to be done.
I have herewith attached the code.
Please kindly help me out.
Thank you
(4,658 Views)
I guess you missed to attach your code.
Ajay MV
(4,620 Views)
