Academic Hardware Products (myDAQ, myRIO)
Driver Aeroprobe for MAX and DAQ
Hi eveybody
I am currently using a ATX4K-7 (AEROPROBE) computer, but I'm looking for making a connection between the CPU given by Aeroprobe and DAQ from LabVIEW.
This CPU is used to sense 7-hole pressure probe. And I want to use LabVIEW and DAQ to get speed plots
However, when I try to find a driver to install in LabVIEW, the different choices does not include Aeroprobe  (or Althen).
Could someone give me the choices to do, so I can find the right driver to download? or is there a driver that can be used for several CPU.
Thank you in advance
Kind regards
(5,916 Views)
Check with the vendor to see what they might have. Otherwise, you will need specs on the communication interface and then write your own driver.
p.s. How is this related to NI Academic products or did you post to the wrong board?
(5,915 Views)
