Academic Hardware Products (myDAQ, myRIO)
ELVIS III -VPS OUTPUT ERROR
The purpose of this program is to make the VPS output negative voltage。However, the actual output cannot obtain negative voltage。
when i run this vi and use the DC voltage gear of the multimeter, the measured output is 0
i use labview 2019 sp2 and elvis iii toolkt 2.2,it is a bug or other?
anyone knows?
Message 1 of 1
(1,607 Views)
