Academic Hardware Products (myDAQ, myRIO)
FPGA output a signal from the C/AO0 MSP connector in myRIO
Hello guys
I am a newcomer to myRIO and  I need to generate a +/- 1V sine signal at 50 kHz with a sample rate of 200kSa/s using the high-throughput FPGA personality. I planed to use the Analog Output Express VI and output the signal from the C/AO0 MSP connector (to get the +/-1V values) but unfortunately, it only works with the A/AO0 MXP connector (for which only positive voltage values from 0 to 5V are available). Moreover, the rate is limited to 80kSa/s.
Is there a way I can customize the Analog Output Express VI for my channel? Or do you have any other advice to achieve my goal?
Thanks for your kind help.
Message 1 of 1
(2,226 Views)
