Academic Hardware Products (myDAQ, myRIO)
Generate sine waveform (myRio)
@CZ_Kevin wrote:
Hi Marc67,
I tried to make some change on the first example to make it fit myrio. But I really do not konw how to do it. It seems like some functions in PXI are using different data type from myrio functions. So just by changing the functions it still not work. And some of the funcions like SinescaleProp.vi can not be found.
Could you show me a little bit how to make it fit in myrio in detail?
BTW, In the second example why the Audio output is used? I tried to change that to Ao but it did not work. I can not get a Sine Wave from Ao. Could you tell me the reason?
Thank you.
Regards
CZ
Did you find any solution for this? I have the exact same issue
Message 11 of 11
(1,091 Views)
