Academic Hardware Products (myDAQ, myRIO)
Get Code Error Err7 Fuzzy Toolkit on Myrio
HI All,
I have already put my file fuzzy.fs to MyRio, I get error code from Fuzzy Load is Err7, My Fuzzy Toolkit not work, How to solve this problem?
Thank You,
(4,085 Views)
Accepted by topic author Iqrom
Error 7 is a file permissions error.  The file probably isn't on the myRIO when your application on the target is running and therefore LabVIEW can't find it.  When using a myRIO, you are basically using another computer (the RT OS on the myRIO itself) to run the VI's that are under the myRIO.
I know you mentioned that it is already on the myRIO but how did you add it to the target?  From the picture you gave it still looks like it has a Windows file extension.
Try this KB to transfer the file onto the myRIO and then change the directory constant to the new file location.
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
(4,044 Views)
Thanks Mr Bear its Work
(4,036 Views)
