Academic Hardware Products (myDAQ, myRIO)
Help Needed to Get cRIO 9012 Working with LabVIEW 2020
Subject:
Hi everyone,
I need some help getting my cRIO 9012 to work with LabVIEW 2020. I've encountered some issues and hope someone here can assist me in resolving them.
Here is my situation:
  1. Ping Success: I can successfully ping the device at 192.168.0.100.
  2. Visible in NI MAX: The cRIO is visible in NI MAX.
  3. Connection Type: The cRIO is only connected via Ethernet. I believe the other port is only for data storage.
  4. Not in LabVIEW: I cannot see the cRIO in the "Targets and Devices" menu in LabVIEW 2020.
  5. Firmware Update: I'm unsure how to perform a firmware update on the cRIO.
Additional Information:
  • LabVIEW Version: 2020
  • cRIO Model: 9012 (older equipment)
Any guidance on how to update the firmware and get the cRIO to show up in LabVIEW would be greatly appreciated. Thank you in advance for your help!
Message 1 of 1
(717 Views)
