Academic Hardware Products (myDAQ, myRIO)
Help for using ACH0 and VPS together in elvis ..??
I am having troubles while initializing VPS on NI ELVIS while Aquiring data from ACH0 at the same time . It says that the device is busy ..??plz suggest what should i do if I want to take an analog input and then manipulate my VPS supply oupput  depending on the out put ..???
(6,388 Views)
Neeraj,
I created the attached VI and tested it on my system, it works fine. Can you try this and see if it works for you?
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(6,368 Views)
