Sir,
I have two VIs. One is the final diode VI that is based on simple LABVIEW simulation code and other is the VI that is given by NI ELVIS instrument as a way to use the variable power supply. Now I have connected a simple diode circuit (diode in series with a resistor) on the NI ELVIS kit. I have also obtained voltages across diode and resistor at channel 0 and channel 1. What I wish to do now is I want to make the Variable Power supply VI automatic..ie it shuld increment in steps of 0.03 and then plot the diode characteristics by obtaining the voltages and current through the NI ELVIS kit..Can you help me in the same. ?
Jay
