Academic Hardware Products (myDAQ, myRIO)
Hokuyo_URG-04LX-UG01_ with NI-MyRIO
Good Afternoon,
I am using myRIO and  URG-04LX-UG01 together and trying to get the distance of the obstacle, but the URG-04LX-UG01 is only giving me magnitudes and directions with a very huge size of array.
I tried to get the distance with practical way to get an equation that represent a relation between the magnitude and distance. but that did not work since the magnitudes were almost the same in all cases.
Any idea how to get the distance ?
(3,894 Views)
Hello AishaRadwan
Have you tried to implement an average with all the data?
Regards
(3,838 Views)
Hello Mr. David22JRA,
You mean to take the average of the magnitudes and the directions?
how that will help to find the distance?
Appreciate your response
(3,835 Views)
Hello AishaRadwan
Could you upload a graphical example?
Feel free to use any graph or any diagram
Regards
(3,825 Views)
Hi the equation is very easy , if you want the magnitude and angle of an obstacle :
The angle of the obstacle:
we had:A (D, Theta) list of vector with distance and angles
Ax=D*cos(Thetha)
Ay=D*sin(Thetha)
AXtotal=Sum(Ax)
AYtotal=Sum(Ay)
angle=atan2(Ay,Ax)
for the distance to the object:
d=sum(D)/(number of distances)
I hope this help
(3,653 Views)
