Academic Hardware Products (myDAQ, myRIO)
How can I add an NSV for a 2D array?
I have tried to connect a 2D array to an NSV. However, there is an issue connecting a 2D array to a 1D NSV. So, how can I change the property of the NSV from 1D to 2D, instead of inserting the functions either BUILD ARRAY for INDEX? Thanks in advance!
(5,923 Views)
Sorry, my question should be how to connect a 1D array to a 2D networked-shared-variable without having to either insert functions of BUILD ARRAY or INDEX between them. To be exact, how can I change the property of a 1D variable to 2D? I cannot seem to find it out.
(5,906 Views)
Accepted by topic author M.Leung
Build Array. You can change the property of a 1D Array to 2D.
In addition, you can try to chang the type of Networke Shared Variable.
(5,893 Views)
Thanks for your answer,Klaus000.
However, what if I don't want to change the property of a 2D array to 1D?  Under this circumstance, how can I change the type of NSV? I cannot seem to find out a 2D NSV. Should I have to create it and how? Thanks again!
(5,881 Views)
About your question, Please make sure you have he Network Variable API. You can follow this link.
http://forums.ni.com/t5/LabWindows-CVI/Network-Shared-Variable-read-string-with-CVI/m-p/3086581
(5,847 Views)
Hi, I have solved the problem myself before your answers. Thanks all the same!
(5,841 Views)
