Academic Hardware Products (myDAQ, myRIO)
How can I see Elvis II boardID
From "NI ELVIS II Pinout Descriptio" I know about
"BoardID<0..7>- These eight lines signify the unique ID of each type of prototyping board by shorting them to VCC or to GROUND."
In my own board I have connect 5volt to boardID pinouts, but I dont know how I can measure my boardID value.
Message 1 of 8
(8,040 Views)
Hi Manushak,
BoardID's are only for third party boards and not NI prototyping boards. Are you developing your own board?
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
Message 2 of 8
(8,025 Views)
Hi Sunaina.
Yes, I have developed my own board.
Message 3 of 8
(8,019 Views)
Hi Manushak,
You would need to get in touch with your Technical Sales Representative by calling 1-888-280-7645.
Sunaina K.
Message 4 of 8
(8,013 Views)
Hi Sunaina
My Elvis II and my own board don't have technical problems.
I want to measure boardID value in my VI, without using digital channels, I can't find function or DAQ property to measure boardID.
Message 5 of 8
(8,008 Views)
Hi Manushak,
If you call the Technical Sales Representative, they will be able to put you in touch with R&D who will be able to help you to incorporae your custom board with Elvis.You can read the boardID by Dev1/channelName_BoardID, where Dev1 is the Elvis Board.
Sunaina K.
Message 6 of 8
(8,002 Views)
Accepted by topic author Manushak
I had exactly the same question
I tried the above and found that Dev1\_BoardID digital lines work and show the ID
Message 7 of 8
(7,955 Views)
tanks, finally I can read the BoardID of my board
Message 8 of 8
(7,947 Views)
