Academic Hardware Products (myDAQ, myRIO)
How can i connect myRIO and computer?
I watched some videos in ni website. I have to use NI Software CD which is in the box. But I can't use because I don't have and cd reader. How can ı use in myRIO in my computer and how can ı embade LabView codes in myRIO?
(3,758 Views)
Actually the software from your CD is not different in any way from a software, which you can download from ni.com website. So you could go on and download it from Required and Optional Software to Program NI myRIO page.
LabVIEW based Robotics - roboticsclub.ru/en/
(3,717 Views)
Sorry for answering an old(er) Post -- I'm new to this Forum (I've been active on the main LabVIEW forum for a decade), and have recently "resurrected" a 6-year-old myRIO.  Here are the steps for connecting myRIO and myPC:
  • Install LabVIEW on myPC.  If you are installing a recent (e.g. LabVIEW 2019 or 2020) version of LabVIEW, you do it by going to NI's site and looking for Software Downloads.  You'll want to have a current LabVIEW License (I'm not sure that LabVIEW Community Edition will support myRIO ...).
  • You start by downloading and installing NIPM, the NI Package Manager, which then acts as the Installer.
  • I recommend that you install 32-bit LabVIEW (on, of course, 64-bit Windows 10).  I also recommend that you install LabVIEW, not LabVIEW NXG.
  • A lot has been written on the main LabVIEW Forum about How to Install LabVIEW, so I'll be brief (and tailor this to installing a LabVIEW + myRIO system, no other Bells nor Whistles):
    • Install just 32-bit LabVIEW.  No Device Drivers, no other software.  Choose only the AddOns (I forget what they are called, "Additional Stuff?") that you are pretty sure you will want/need.  Reboot (after each of the following steps, also reboot).
    • Install LabVIEW Real-Time (since the myRIO is a LabVIEW Real-Time Target).  Again, nothing else.  Reboot.
    • Install Drivers.  You want DAQmx and VISA.  You (probably) don't need IEEE-488.2.  Reboot.
    • Install the myRIO Toolkit appropriate for your LabVIEW version.  You might need to hunt for it in NIPM.  Reboot.
  • Start LabVIEW, activate its licenses.  Open MAX.  Plug in your myRIO using its USB connector and, if everything goes well, you'll hear the little "USB sound" and a Welcome to myRIO app will run, inviting you to configure myRIO.
  • You might need to use MAX to update the firmware of the myRIO, as it needs to be consistent with the myRIO Toolkit you just installed.
Bob Schor
(3,331 Views)
