Academic Hardware Products (myDAQ, myRIO)
How many RS485 Devices can be connected to myRIO? - URGENT
I want to connect ateast three RS485 Devices with myRIO. Two of the devices don't have Clock Signal whilst the third device does have?
I want to know how should I connect them and if any converter is required then which one is the most suitable one?
Thank You
(556 Views)
Have you tried doing a Web Search with "myRIO and RS-485"?  This question has also been asked here on the LabVIEW Forums.  This is definitely not "built-in", but can be done, with a reasonable (?) amount of effort.  Note that you may also need some digital circuitry to change the TTL levels from the myRIO's DIO lines to the pulse levels specified in the RS-485 standard.  It means "programming to the RS-485 standard".  I didn't do an exhaustive Web search -- it is possible that you might find a good desciption of "how to do this" (or, even better, find someone who has built a circuit or a chip to do the translation for you ...).
Bob Schor
(484 Views)
