05-12-2023 08:49 AM - edited 05-12-2023 08:53 AM
I am attempting to create a linear simulation vibration platform to test the response frequency of a seismometer. Therefore, I need an oscillation system based on a sine wave. This means that the platform should be able to simulate oscillation by providing the desired oscillation frequency and velocity. I am facing some difficulties. The parameters for the stepper motor are: 800 pulses per revolution, and the platform parameters indicate that the motor rotates one revolution to move 7.2cm. My LabVIEW loop speed is set to 1000Hz. How can I calculate the PWM value for each iteration of the loop? For example, if I want to perform a sinusoidal vibration at 10Hz and 20cm/s velocity. I am encountering difficulties and would appreciate your assistance. Thank . Note: DIR denotes the motor rotation direction, PUL represents the pulse signal, and ENA indicates whether the motor is enabled.
However, I found that each second of the loop only generates about 685 SIN values. Shouldn’t it be 1000?
05-13-2023 03:05 AM
I want to do something like this https://youtu.be/WEu9fwv5eoc
06-02-2023 03:36 PM
You've attached no useful information. The photograph of "something" is at a strange angle, and from fairly far away. What does it show? Are there (physical) wires in there? Do you think we can "see how it is connected"? [I certainly cannot see anything useful here]. Where is the (hardware) "wiring diagram"?
Pictures of LabVIEW code are a complete waste of my time. You need to compress the LabVIEW Real-Time Project folder (right-click the folder, choose "Send to:", "Compressed (zipped) folder") and attach the resulting .zip file to your reply.
Bob Schor
