Academic Hardware Products (myDAQ, myRIO)
How to plot I-V characteristics of nonlinear device which gives pinched hysterics?
I want to plot I-V characteristics of memristor where I need to apply a sinusoidal voltage input and plot voltage versus current
I tried Two wire current voltage analyzer but it doesn't work well.
What can I do to plot the output current of voltage source?
(5,779 Views)
Once you adquire the data you should be able to use a chart or graph to display it.  You mention that you have it working, but not well?  What is not working well about it?  What code are you running right now?
Shane C
(5,757 Views)
