Academic Hardware Products (myDAQ, myRIO)
How to use the software?
I think it would be better if you have changed the driver to latest updated version. I am also not an expert in this. So, I may prouduce you with the best solution by consulting one of my friends having complete knowledge about this.
forcebattery
Message 11 of 18
(4,118 Views)
Ok, I am a little confuse with the pin output vs port output. I am assuming pin output = BNC 2090 while the port output is the output from the actual port shown in the data sheet. Therefore, if I am going to try to connect the LED directly to the Daq I will be using port output correct?
Message 12 of 18
(4,106 Views)
I'm a little confused as to what you mean when you're referencing port outputs and pin outputs.
You should be able to select a port on your device in NI MAX or LabVIEW. The name of this port corresponds to a certain pin on your device.
The pinout on the datasheet should list the pins and corresponding ports adjacent to each other.
Mike
Message 13 of 18
(4,099 Views)
Ok, in this image "http://forums.ni.com/ni/attachments/ni/10/2115/2/lin%20output.png" what does line output and port output mean?
Message 14 of 18
(4,094 Views)
A line is a single digital I/O while a port is multiple lines (i.e. lines 0-7).
Message 15 of 18
(4,083 Views)
Ok, I thought 1 line = the controller for BNC 2090. So can anyone tell me how to use the software to use BNC 2090?
Message 16 of 18
(4,079 Views)
That is incorrect. When I drop down the line output tab there is port 0 to 7. However, when I drop down the port output tab there is only port 0.
Message 17 of 18
(4,055 Views)
Hey hunkeelin,
Someone asked a similar question in another thread on the forums. Here is the link to that thread.
Paolo F.
Message 18 of 18
(4,031 Views)
