Academic Hardware Products (myDAQ, myRIO)
How to use thermocouple on myRIO 1900 ?
I have a J-type thermocouple, sensing temperatures between -50°C and 350°C.
Which channel should I use on myRIO to intercept the signal? How much voltage input is most appropriate?
Is it still missing some other hardware devices?
I am not an electronic engineer, but anxious to solve this problem, please help me.
(3,662 Views)
you need an interface IC to convert between the milivolts from the J to a value for myrio
(3,575 Views)
If you could provide the specification sheet it would be easy to see if it's just a thermocouple or a thermocouple with interface IC
(3,565 Views)
