11-13-2018 02:22 AM
Hello everyone, I am a beginner about using myrio-1900, so I have some problem about it. By the way, sorry about my poor English.
The aim of my project is measuring the EEG signal by using myrio-1900 and some electrodes. I had learned Labview and NI ELVIS since last years. I can use Labview and Elvis to measure EEG signal without any problem, but I can't measure it by myrio-1900. I use DAQ Assistant function to get the signal on Elvis, and I use myrio analog input function to get the signal from electrodes. I don't know why I can't get signal. Is it a wrong function or do I need to use another function? I saw many people use this function to get the signal easily.
If anyone understand what I am talking about, please reply me or send my a message. Thanks for your reading.
11-14-2018 08:12 AM
Hi Wen,
Did you get any error message?
It would be help if you provide the development environment, such as the OS version, LabVIEW version, and please check the software on your myRIO.
By the way, you can post your issue on the local forum. e.g. NI產品與技術 討論區, ディスカッションフォーラム(日本語).
Jane
11-20-2018 09:58 PM
Hi Jane
I didn't get any error messenger. The VI can run, but it get the wrong signal I think.
Thanks for your reply. I will try to post my situation on the local forum.
11-21-2018 07:52 PM
Hi Wen,
Could you provide the screenshot of the wrong signal?
There is a suggestion for you to install myRIO Toolkit to get started.
Jane
