Is the NI MyDAQ fully supported in the same ways as USB-6501, USB-6008, etc ?
1. Is there a model number for myDAQ like the USB-6501, USB-6008?
2. The documentation says Labview is supported. Will labwindows work with myDAQ? Based on
casual scanning of other conversations here, it appears that DAQmx is the common driver
that must be present for Labview and LabWindows?, Measurement Studio and non Measurement
Studio environments (i.e, Microsoft Visual Studio) to run.
3. Can myDAQ be simulated in software? If so, how? Where is it in the simulated NI-DAQmx device list in MAX?
4. I would assume .NET would be slower to operate than native code in C++ or C, correct?
