Academic Hardware Products (myDAQ, myRIO)
Labview- Error -50103 occurred at DAQmx Start Task.vi:6
Hello.
I am finished with my course equivalence to 12 years, and I have to prepare a projecto.
So I'm having a problem with my program. the proble is:
This http://img22.imageshack.us/img22/297/errordaq.png
thia problem happens when I use more than 4 Daq assistence, but if I use 4 Daq assistence program runs correctly.
If anyone can help I would appreciate very much.
Regards Carlos
(8,110 Views)
Hello Carlos,
The error message is quite explicit; some ressource is not avilable to perform the operation you requested.
Basically, a DAQ hardware contains four measurement functions:
  1. Analog Input (AI)
  2. Analog Output (AO)
  3. Digital Input Output (DIO)
  4. Coutner (CTR)
For most of DAQ hardware, you have one clock engine per kind of operation (this have been imporved for X Series); so depending on the hardware you are using, this error will occur if you are trying to run two analog input task.
Hope this helps,
(8,093 Views)
Hello Mathieu R.
Already bound by restoring.
I have had training aquesição data by computer, except that my teacher does not understand anything.
My final project consists of a house intelegent controlled with NI6009.
I'm going to perform two tasks percise analog input. Is it possible to run another program?
Will you help me?
Regards Carlos
(8,080 Views)
someone help me?
was very grateful
(8,049 Views)
