Academic Hardware Products (myDAQ, myRIO)
Matlab: analog audio input/output
Hello NI!
Im using the Data Acquistion Toolbox in Matlab for receiving analog data from myDAQ.
By now I have found no possibility to use the analog audio input/output.
'daq.getDevices' only gives me the two analog I/O ports, not the audio ones:
 'Analog input subsystem supports:
      -2.0 to +2.0 Volts,-10 to +10 Volts ranges
      Rates from 0.1 to 200000.0 scans/sec
      2 channels ('ai0','ai1')
      'Voltage' measurement type'
Is there a possibility to use the audio ports in Matlab?
(6,443 Views)
What kind of hardware do you have exactly? Do you have installed all drivers? How do you want to connect the Hardware in Matlab? Please post a screenshot or something else.
Kind regards
(6,423 Views)
I have the "NI myDAQ Student Instrumentation Device". I have installed the newest versions and already worked with the "ELVISmx Instrument launcher" and with the "mydaq_equalizer.vi" with LabVIEW. Everything works fine.
Now I wanted to send music data to Matlab through the "Audio in" port of the myDAQ and receiving it with the "Data Acquisition Toolbox". Like I posted the toolbox doesnt recognize the audio ports.
(6,380 Views)
Hello, you are right, there is 1 stereo audio input. The input type is line-in or microphone. The data acquistion toolbox, which should recognize the audio input, is from MathWorks. So I cannot say anything about that. Please contact the MathWorks Technical Support.
Thank you.
(6,372 Views)
