Academic Hardware Products (myDAQ, myRIO)
Multiple Digital Output Generation
Hi
I require to ouput more than one square wave forms (whose parameters can be changed as per the requirement) using the digital i/O of the M6259 Daq using labview 7.1.
I have attached the sample programme.
In it  I see the output at DIG 0 (and I can switch on and off change parameters of the square waveform generated on that channel) . However  the output is always 0 at DIG 1. (The ouputs were seen using an oscilloscope). I have included two seperate data output streams in the programme (start-write etc) to generate the two outputs in the programme. Will this work? Or is there any modifications/changes I should do?
Appreciate any help with this regard. Thanks
Mal
(6,988 Views)
This is being answered on this forum:
http://forums.ni.com/ni/board/message?board.id=250&message.id=22239&view=by_date_ascending&page=1
Sarah
Applications Engineer | National Instruments | UK & Ireland
(6,977 Views)
