12-07-2014 09:24 PM
Hi Everyone,
I have a simple code to detect the voltage level at analog input 1 and compare it with a threshold value to trigger the LED using myRIO FPGA.
However, the value obtained from analog input didn't seem right. When the input is 0V, the reading is about 5; when the input is 3.3V, the reading is about 2700; and when the input is 5V, the reading is about 4000.
It seems that the scale of reading is not correct. I am just wondering if there is any way to make the input signal reflect the real voltage level so I can easily choose the threshold value.
Thank you.
Jing
12-08-2014 02:42 AM
Ahh, problem solved. I failed to consider 12 bits ADC in my program...
So the input voltage value needs to be divided by 2^12 to get the actual voltage level.
But i am still curious why this convertion problem only appears in fpga program rather than in the realtime program. Anyone can help?
Thank,
Jing
12-09-2014 01:51 AM
Hi JingTY,
Don't if this will help
TuiTui
12-09-2014 02:01 AM
Hi Jing,
More information as follow,
You can browse through the user guide and specification sheet.
http://www.ni.com/pdf/manuals/376047a.pdf
On page 10 of the manual, There is a sentence states that the returned value by FPGA I/O node is Raw data value.
There is more explanation on FPGA data type in this link below,
http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/decide_data_type/
TuiTui
12-09-2014 03:13 AM
Hi TuiTui,
Thank you very much for your help. Now I understand the FPGA I/O Node always return Raw Data Value.
By the way, may I check with you how to do division in FPGA? My labview program cannot compile division calculation. Is it correct?
Thanks.
Jing
12-09-2014 02:13 PM
What kind of division are you doing? If it's the special case where you're dividing by a power of 2, you can always use a bit-shift.
12-09-2014 06:32 PM
Hi Natasftw,
Yes, I need to divide the raw data by 2^12 (12-bit ADC) and then multiply by 5 to get the actual voltage level. Could you be more specific on how to do bit-shift?
Thank you.
Best,
Jing
12-11-2014 01:42 AM
Hi Jing,
Great to hear that the information help!!
You might want to look at this white paper. I hope this will help you understand more on why the divide function doesn't work well in FPGA
http://www.ni.com/white-paper/3661/en/
There also a forum post about dividing in below link,
http://forums.ni.com/t5/LabVIEW/Dividing-in-FPGA/td-p/189324
TuiTui
12-12-2014 04:17 AM
Thank you!
12-12-2014 09:56 PM
The thread TuiTui linked had a small example showing the bitshift. Multiplying by 2^-12 is the same as dividing by 2^12. In terms of understanding a bitshift, look at three binary numbers: 100 010 001. If we start from the left, we see 4 2 1. You can notice shifting the bit one spot divides by 2. That's why bitshifting can be used in the very specific case where you're working with a power of 2. It's a trick that's used rather frequently in DSP applications as the cycle cost for a bitshift is usually 1 while divides can be much more. But, make sure you're careful with this. If you bitshift by 12, you're only going to maintain your 4 MSBs in a 16-bit word. The other 12 are all shifted to the right of the word and become 0s.
