Academic Hardware Products (myDAQ, myRIO)
MyRio Startup Time
We are currently using the MyRio to run our Formula Hybrid Racecar.  We have loaded on a RT application and programmed it to run on startup.  It works just fine but takes 20-22 seconds to start running the RT program when the system is powered.  We are running very simple code with no modifications to the FPGI.  Is there a way to improve the startup time of the MyRio?
Joseph Belter
Yale Bulldogs Racing
bulldogsracing.com
(6,170 Views)
Hey Joseph,
The myRIO runs the NI Linux Real-Time operating system.  When you power on the myRIO the OS loads, then the necessary drivers load, then your startup application can start running.  A lot of the boot time is due to the OS and there is nothing the user can do to speed this up.  If you have a bunch of drivers installed (software you installed through MAX) that you are not using you may be able to improve the boot time by removing the unused drivers.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(6,154 Views)
