Academic Hardware Products (myDAQ, myRIO)
Myrio USB communication with Teensy
Hi All,
I wonder if someone would have a solution to an issue I have been trying to overcome over the past few days.
I am trying to pass data between a Teensy microcontroller and the Myrio, using the Myrio's usb port. The issue is that NI MAX can see the Teensy as a ACM0 device, yet it's status is not present. Prior to attempting to connect to the Myrio, I was successful in passing data between the Teensy and a Computer, where NI MAX was able to open VISA Test Panel and read the incoming data.
I am using Labview 2016 build, along with appropriate toolkits.
Any avenues to explore would be very much appreciated, as I have tried many of the related topics to no avail.
Kind Regards,
Luke.
(3,211 Views)
Hi all,
Simple solution: SSH into the myRio and run the command "chmod a+rw /dev/ttyACM0". This is a non permanent fix, as doing it this way you will need to run the command after every reboot on the myRio.
(3,141 Views)
