Academic Hardware Products (myDAQ, myRIO)
NI Digital Electronics FPGA Board Driver Windows 7 64-bit
It appears the latest driver for the FPGA board had not been developped for Windows 7 64 bit (http://joule.ni.com/nidu/cds/view/p/id/2166/lang/en).
What about the rest of us having such a platform?
Is there any trick to convince the platform to accept this driver?
(9,087 Views)
Typically these will install with the Windows-on-windows where a 64 bit Windows system can install 32 bit programs. Try the installation and see if it works.
Ben J.
(9,064 Views)
 NicB
We're aware of the issue and plan on supporting Windows Vista and Windows 7 64-bit in the next release.  Unfortunately, due to some issues, 3.1 will not work for 64-bit Windows versions (while BenJ is correct, in this case a component we depend on did not work with the WOW64 framework that supports 32-bit binaries interacting with 64-bit drivers)
Brad M.
Staff Computer Engineer
LabVIEW FPGA
(8,778 Views)
Hi BradM,
I also have a 64-bit Windows 7, I'm wondering if the LabVIEV FPGA Module that can run on this system has already been realeased?
thx!
(7,847 Views)
ron3721,
Yes, the version of the driver released that supports LabVIEW 2011sp1 and later have the changes required to work on a 64-bit Windows system. I believe the number of the release that supports 2011sp1 is 4.3, although the download page/requirements/Readme should be consulted
(7,843 Views)
Hey ron3721,
It has indeed. We have 2 versions that will work, and the one that you want depends on what version of LabVIEW you have. If you use 2011 SP1, you will want the 4.3 driver, and if you use 2012 you will want the 5.2 driver.
Cheers!
TJ G
(7,841 Views)
