Academic Hardware Products (myDAQ, myRIO)
NI ELVISmx Instrument Launcher fails to start
NI ELVISmx Instrument Launcher fails to start and the following errors are logged in Windows Event Viewer:
Application Error:
Faulting application name: niiql.exe, version: 19.0.0.49152, time stamp: 0x5ca2d8c3
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1320, time stamp: 0xc5d2312e
Exception code: 0xe0434352
Fault offset: 0x0012b4f2
Faulting process id: 0x1d28
Faulting application start time: 0x01d7dc6f271085ca
Faulting application path: C:\Program Files (x86)\National Instruments\NI ELVISmx Instrument Launcher\niiql.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 371d359d-33ce-4969-a89a-fd4e4719da4f
Faulting package full name:
Faulting package-relative application ID:
NET Runtime error:
Application: niiql.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
at NationalInstruments.InstrumentQuickLauncher.ELVISmx.ElvisDaqSystem.MonitorDaqSystem()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
This occurs on all laboratory computers with the latest 64-bit Windows 10 (Windows 10 Enterprise 21H1) and with up-to-date Windows Updates, and with latest Academic Site License (2021 Spring distribution with. LabVIEW 2021 and NI ELVISmx 19.0). Individual NI ELVIS instrument's can be lunched from start menu.
Is there any solution?
Thank you.
(2,947 Views)
We have the same problem....and no solutions...
(2,907 Views)
Try renaming (or deleting) the Users/<userid>/AppData/Local/National Instruments/NI Elvismx Instrument Launcher folder. This worked for me.
(2,674 Views)
