06-25-2013 01:39 AM
How to use NI-myDAQ with Labview 12 /64bits without installing 32 bits service pack?
06-26-2013 10:14 AM
06-26-2013 11:17 AM
While ELVISmx (an application that helps users get started with MyDAQ) does not support LabVIEW 64-bit, NI-DAQmx, the driver for MyDAQ, supports LabVIEW 64-bit just fine.
06-26-2013 02:02 PM
That's true, you will still be able to use the hardware NI myDAQ with DAQmx to acquire data in the LabVIEW 64bit, the only disadvantage is that you won't be able to use the ELVISmx Soft Front Panels that are ready-to-use instruments that will make your acquisitions easier.
