Academic Hardware Products (myDAQ, myRIO)
NI myDAQ reading Funspark SHT15 temperature&humidity sensor problem
Hi, everyone, I have a problem with using NI myDAQ reading SHT15 sensor, and showing the results in Labview. As this sensor needs setting clock signal, I don't know how to do with that, as no examples are showed, now I'm stuck. if any help, I will appreciate.
(4,143 Views)
Hey Kevin,
Here’s a link to another discussion that goes over generating a basic clock signal with a myDAQ:
http://forums.ni.com/t5/LabVIEW/generating-clock-using-mydaq/td-p/3111171
There’s also a basic example near the bottom of the page. Take a look at that and give it a try.
Cason
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(4,123 Views)
