Academic Hardware Products (myDAQ, myRIO)
Not really an NI related question
 But I do not know a better place to pose this question (suggestions are welcome).
I have a set of instruments that all need to connect to the same probe station at different points in time during the course of a measurement.
They have coax/triax outputs. Is there a GPIB controlled BNC multiplexer on the market that I could use with LabVIEW. Googling has led to a few candidates but none of them appear to be LabVIEW compatible (they have their own software, which is useless for my application since I need LabVIEW to be able to control what switches when) ?
(6,236 Views)
I think this could solve your problem.  Check out the CA-1000. It's a configurable, passive enclosure. You can add the BNC Connector Panelette p/n 184737-01, which contains two BNC's each. You can then solder all the connections together inside, or use a CB-50LP screw-terminal block to connect them.
(6,227 Views)
I may be missing something, but in the datasheet, I did not see a control interface (hopefully IEEE-488). Can you explain how it might work ?
(6,194 Views)
Lets keep everything to one thread.
(6,173 Views)
