Academic Hardware Products (myDAQ, myRIO)
Object Counter Using Infrared Sensor
I am currently a final-year student doing my project and I need help with it. I want to use myRIO SHARP GP2Y0A21YK0F Infrared Proximity Sensor to count the objects while reading data. How do I achieve this?
(5,185 Views)
Accepted by topic author syakirin
First connect the sensor to an anlog input and supply it with 5V
Depending on counting speed and object length or pulse length , choose a meaningfull samplerate.
Now you can capture the voltage reading.
If you look at the datasheet you can expect a voltage waveform for your object. (Better choose a min distance to avoid the foldback at the near end 😉 )
depending on the needed samplerate and your setup you now just have to use the threshold detection or do a window detection, like has to be higher than v_h and then lower than v_l to have an item counted.
Greetings from Germany
Henrik
LV since v3.1
(5,143 Views)
Thanks! 😊
(5,128 Views)
Hi, can you show me the VI of it? I would be gladly appreciate it!
(5,117 Views)
Hi, Henrik
I don't understand what you mean by "counting speed and object length"...
Can you give me the VI snippet on it?
Thanks!
(5,059 Views)
