Academic Hardware Products (myDAQ, myRIO)
Problems triggering with NI-myDAQ, error: 200077
I am trying to do analog edge triggering on an analog output, but whenever I try to add a triggering block it throws error -200077, and tells me...
Property: Ref.TrigType
You Have Requested: Analog Edge
You Can Select: None
I'm pretty sure that my hardware supports analog triggering because I can trigger in the pre-compiled NI ELVISmx tools.
Any ideas?
(7,345 Views)
Hello 🙂
Just to clarify, are you attempting to trigger the device based on an output from the device?
Product Support Engineer
(7,322 Views)
myDAQ does not support analog triggering in HW, so the ELVISmx software does it by using a continuously-acquiring task.  For some reason it didn't get ported to the express block.  Luckily someone did this for you.
http://decibel.ni.com/content/docs/DOC-5583
(7,315 Views)
gaving: Thanks! I'll take a look at those VIs
James 😧 Actually I did want to trigger on an analog output but I thought it would be easier to generate a trigger output which is read by an analog input and trigger on that (since I thought the myDAQ had analog trigger capabilities). Since I need to implement custom triggering code anyway, do you know if the myDAQ has access to ao/StartTrigger?
(7,298 Views)
