Academic Hardware Products (myDAQ, myRIO)
Python Example code for NI 9229
Yes, it was issue with an 2.7.13. Thanks!
Message 11 of 12
(1,647 Views)
Hi all,
My reading is different than the current probe reading. I see that the possibility could be because the minimum input signal that my device receives is 96 mA (~96 uV) using a sense resistor of 0.1 ohm whereas current probe only measures 30 mA. Is there a possibility that the signal range for NI-9229 might be playing an important role? If so, how do I change the input signal range from +/- 60V to +/-10V in python? Also, what if my one analog input signal range has +/-60V and another +/-100mV? Is there a way to handle each signal range?
Message 12 of 12
(1,586 Views)
