11-14-2011 11:25 AM
Hi all,
I have a doubt regarding the possibility of using the NI DAQPad 6015 to get the data from a flow meter that sends the info as an AC voltage pulse. Basically, this is not my area of expertise and I am trying to sort out as much as I can with my limited knowledge. I do not possess the manual for the DAQ and since I inherited it from a previous researcher I am trying to find out if I need a new piece of hardware or I can make the current configuration work.
Thanks.
11-15-2011 11:11 AM
Hello Yankeeve,
Yes you can do any analog measurement with your NI DAQPad 6015 as long as it is withing range of the analog channels. You can get extra info on these links.
Portable High-Performance Multifunction DAQ for USB
http://www.ni.com/pdf/products/us/ni_daqpad_601x.pdf
NI DAQPad-6015/6016 Family Specifications
http://www.ni.com/pdf/manuals/370969b.pdf
Have a nice day,
