Academic Hardware Products (myDAQ, myRIO)
Run as startup
If I've designated a RealTime application from one project to Run as Startup , then later select a different RT App from a different project to Run as Startup , should it always choose the latter ? I tried this and neither is running when I power up - do I need to Unselect the first app ?
(5,615 Views)
 Hi Edean,
If you configure an application to Run as Start Up and deploy it to your real time target then after resetting the target if will immediately run that application. If you deploy another application to your target then it will “forget” about the previous deploy and set the new one as start up application. You can also include multiple start up VIs in your application. Take a look at the links below, they may help you understand this process better.
http://digital.ni.com/public.nsf/allkb/96EF15C3A86A40C8862579920082C594?OpenDocument
http://digital.ni.com/public.nsf/allkb/466EA9705F98E07786257687005E081B?OpenDocument
I hope you find this information useful.
kruiz17
(5,599 Views)
