Academic Hardware Products (myDAQ, myRIO)
Security System Example For Freesacle Microcontroller Kit
Dears,
I need the Example For the Security System Using the Freescale Microcontroller Kit with LabVIEW.
this Example Can Be Seen on the Web cast For NI ELVIS Embedded Design:
http://ni.adobeconnect.com/p35906816/?launcher=false&fcsContent=true&pbMode=normal
Ahmed Abdulbaky
(8,231 Views)
Hi AhmedAbdulbaky,
I will try to find this application, however the examples for the webcasts are not always avaliable. I will post an update with my findings. Thanks.
Steven K.
Software Engineer
(8,217 Views)
I was able to find it. It is attached below.
Steven K.
Software Engineer
(8,208 Views)
I know that is a very old thread but may I ask for the firmware of the frescale that works together with the Security System VI's.
Thank you.
(7,520 Views)
What hardware are you using? Take a look at this forum post on the Freescale forums. It looks like they use BDM Firmware: https://community.freescale.com/thread/304404
Thanks!
Stephanie S.
Application Engineer
(7,501 Views)
I am using the Freescale HCS12 Microcontroller Experimenter. Its the one that is used together with NI Elvis II.
The board comes with an MC9S12C128 MCU.
I need that firmware so to inspire my students for their project development using freecale board and labview.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202706
Thank you
(7,496 Views)
I am also using same security vi's and having NI ELVIS II freescale board using HCS12 microcontroller P&E USB BDM Multilink option, but I am getting the error of 200559 while running my vi's as in my post.
Ali Tariq Bhatti
Advice: Some people talk on different issues and abusive against your post because they do not want to help and arguing with you on some other topic. You all will observe and I also observed, so also do not want to mention their name and best way is complaint them to the moderator. If anyone still wants to talk on different issues against the post, other way is to do private message.
~~~Be nice, have faith in ALLAH(God)~~~
(7,060 Views)
