Academic Hardware Products (myDAQ, myRIO)
Sonic Range Finder MB1010 - 3 in myRIO or analog input
Hi!
At the beginning - I'm new here.
I've got a problem. In my project I need to instal on myRIO 3 Sonic Range Finders (MB1010). But in basic connect I need the UART.RX connection on myRIO. But there is only two - first on connector A and second on connector B. How can I connect the third Sonic Range Finder?
Is there any way to extend UART.RX input? Or maybe I should use some anagol inputs? If jest - will be some difference between analog and digital signal?
Thank you for help.
Karol
Message 1 of 1
(2,752 Views)
