Academic Hardware Products (myDAQ, myRIO)
Time domain multiplexing through my rio 1900
Hii,
a) We are trying to multiplex two signal generated through inbuilt VI
b) And  output the same generated signal  through the DAC
c) & Passing the same generated signal to 2 different analog input of My Rio 1900
d) Both the signal are switch on for a fraction of time(user defined in hz) in a sequential way so that for each fraction of switching the signal 1 goes to its dedicated analog input 1 and signal 2 goes to other dedicated input 2
&when we try to do this we get the following error code 50400.
Kindly suggest.
Thanking you,
AR
(2,466 Views)
Thank you so much for attaching all of your code, including the Project file, so we could see the problem you are describing and attempt to fix it.  Somehow, however, the attachment didn't come through when I tried to open it, so without having any idea what you tried to do, nor a way to duplicate it and maybe figure out a way that works, I regret I can't provide much help.
There is no Error Code "50400".  Did you learn in school about "signed numbers"?  Could you have forgotten to include the sign of the Error Code?  [Had we had actual code to test, I wouldn't have to ask such a silly question ...].
Bob Schor
(2,369 Views)
