Academic Hardware Products (myDAQ, myRIO)
USB-6009 Sine Wave
I am new to LabView and am having some trouble. I need to input two sine waves into a USB-6009. I have a voltmeter that should read the output. Two of the problems that I have had thus far: I can only use "On Demand" in DAQ Assistant and even when I throw the DAQ Assistant into a while loop I still do not get a readout on my voltmeter. Any suggestions? Thanks for the help.
(6,026 Views)
That is confusing. You say you need to input 2 sine waves into a 6009 and that to me implies that you are doing a DAQmx Read. Then you say you have a voltmeter to read the output. That implies you are doing a DAQmx Write. If you are really doing a write from the 6009, then on demand is, of course your only choice. As the specs clearly indicate, the output of the 6009 is strictly software timed so you would need to pass a sine wave point by point and then you would have very little control over the frequency. And, again as the specs clearly state, the fastest output rate you could expect is 150Samples/sec.
(6,014 Views)
