01-10-2007 04:26 AM
01-10-2007 07:52 AM - edited 01-10-2007 07:52 AM
Message Edited by I.Knoblich on 01-10-2007 02:53 PM
Message Edited by I.Knoblich on 01-10-2007 02:58 PM
01-10-2007 08:23 AM
hello Knoblich,
I have problem with your file, because I am using a older version of Labview (8.0). May you send me the same file, but for labview 8? Please
01-10-2007 12:02 PM
01-11-2007 02:31 AM
Hello Ingo,
Well have some problems in the file, first miss a vi (WDT Index Channel DBL.vi) and after when I run have a error:
Error -20315 occurred at NI_MABase.lvlib:ma_Check Waveform Timing.vi (waveform index 1 of 2)
Possible reason(s):
Analysis: The waveform dt parameter is <= 0.
Maybe because the missed vi.
But if I understood this application is for every kind of simulation in multisim. isnt? So, I am trying to use the ELVIS schematic is different, that means, is that different or not? Thats the point I was looking for read something about it, but is completly difficult to find. Can you help me in this point?
01-11-2007 03:03 AM
Sorry...
The files are working perfectly... but the question about the ELVIS schematic is the same!!!
thanks
01-12-2007 12:22 PM
01-19-2007 07:50 AM
Thanks, your link was great, I just want to understand the begging at the begin..haha
About your program, thats working perfect, but some times the align vi is not align the waves, and sometimes I want to compare two different waves one after other, the first one work out, but the second when I compare we have a error (dt<=0), can u help me again?
thanks a lot
01-19-2007 08:01 AM
01-25-2007 01:59 AM
